ArcGIS.Desktop.Core.Portal Namespace / PortalQueryParameters Class / StartIndex Property
    StartIndex Property
    Gets or sets the index of the first entry in the result set response. The index number is 1-based. The default value of StartIndex is 1 (e.g.,. the first search result). The start index, along with the Limit parameter can be used to paginate the search results.
    Syntax
    Public Property StartIndex As Integer
    public int StartIndex {get; set;}
    Remarks
    Corresponds to the "start=" parameter of a portal REST query. When not specified, start is assumed to be 1
    Requirements
