ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / GetVoronoiRegion Method
A polygon to clip the Voronoi region. This can be null. If null, a default rectangle (larger than the full extent of the TIN) will be used to clip the Voronoi region.
    Gets the Voronoi polygon region for this node. The Voronoi region (also known as Thiessen or proximal polygon) encloses an area that is closer to the source node than to any other node in the triangulation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetVoronoiRegion( _
       Optional ByVal clipPolygon As Polygon _
    ) As Polygon
    public Polygon GetVoronoiRegion(
       Polygon clipPolygon
    Parameters
    clipPolygon
    Return Value
    Remarks
    Null is returned if this is called on a super node.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
