ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class
    TinNode Class Properties
    For a list of all members of this type, see TinNode members.
    Public Properties
     NameDescription
    Public PropertyGets a ArcGIS.Core.Geometry.Coordinate2D structure with the X and Y values. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyGets a ArcGIS.Core.Geometry.Coordinate3D structure with the X, Y, and Z values. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden. Gets the TinElementType of this instance. Always returns TinElementType.Node.
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public PropertyOverridden.  Gets a value indicating if this TIN node has Z-less vertices. If the z-value of a vertex is NaN, then it is considered z-less. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets the index number of this TIN element. The base index number for TIN elements is 1. (Inherited from ArcGIS.Core.Data.Analyst3D.TinElement)
    Public PropertyOverridden.  Gets a value indicating whether or not this element is empty. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden. Gets if this element is within the interpolation zone or the data area of the TIN. See TinDataset.GetDataArea. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyGets if this node is on the TIN domain boundary. That is, if it is on the boundary of the interpolation zone or data area. See TinDataset.GetDataArea. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyGets the length of this TIN element. The length is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. (Inherited from ArcGIS.Core.Data.Analyst3D.TinElement)
    Public PropertyOverridden.  Gets the node count of the element. Always returns 1.
    Public Property Gets the source of this TIN node. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden.  Gets the tag value of this TIN node. This method must be called on the MCT. Use QueuedTask.Run.
    Top
