ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / GetPointsBetweenZs Method
The minimum Z value.
The maximum Z value.
Example
    Gets the set of coordinates for this TIN triangle that falls within the specified Z values. Use these coordinates to build a 3D polygonal definition for the area of the triangle that falls within the specified Z values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPointsBetweenZs( _
       ByVal minZ As Double, _
       ByVal maxZ As Double _
    ) As IReadOnlyList(Of Coordinate3D)
    public IReadOnlyList<Coordinate3D> GetPointsBetweenZs(
       double minZ,
       double maxZ
    Parameters
    minZ
    maxZ
    Return Value
    Exceptions
    ExceptionDescription
    minZ and maxZ cannot be NaN values.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    TIN Triangles
      // nodes, edges of the triangle
      var triNnodes = triangle.Nodes;
      var triEdges = triangle.Edges;
      // triangle geometry
      polygon = triangle.ToPolygon();
      // triangle length
      var triLength = triangle.Length;
      // triangle area
      var triArea = triangle.Area;
      // is the triangle "inside"
      var isInsideTriangle = triangle.IsInsideDataArea;
      // triangle aspect and slope  (radians)
      var aspect = triangle.Aspect;
      var slope = triangle.Slope;
      // get centroid
      var centroid = triangle.GetCentroid();
      // get normal
      var normal = triangle.GetNormal();
      // get adjacent triangles
      var adjTriangles = triangle.GetAdjacentTriangles();
      // get area of triangle that falls between the z values
      double minZ = 1.0;
      double maxZ = 3.0;
      IReadOnlyList<Coordinate3D> coords = triangle.GetPointsBetweenZs(minZ, maxZ);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
