ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / GetUnitNormal Method
    Gets the vector normal to this TIN triangle, adjusted to a magnitude of one. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetUnitNormal() As Coordinate3D
    public Coordinate3D GetUnitNormal()
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
