Parameters
- extent
- The extent. This will be projected into the spatial reference of the TIN dataset. If the input envelope doesn't have a spatial reference, then the spatial reference of the TIN is assumed.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
| System.ArgumentNullException | Extent is null. |
