ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / Aspect Property
Example
    Aspect Property (TinTriangle)
    Gets the aspect of this TIN triangle in radians. The aspect is the compass direction of the steepest downhill slope of the triangle. A value of 0 radians is due North, PI / 2 radians due East, PI radians due South, 3 * PI / 2 due West, etc. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property Aspect As Double
    public double Aspect {get;}
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    TIN Triangles
      // nodes, edges of the triangle
      var triNnodes = triangle.Nodes;
      var triEdges = triangle.Edges;
      // triangle geometry
      polygon = triangle.ToPolygon();
      // triangle length
      var triLength = triangle.Length;
      // triangle area
      var triArea = triangle.Area;
      // is the triangle "inside"
      var isInsideTriangle = triangle.IsInsideDataArea;
      // triangle aspect and slope  (radians)
      var aspect = triangle.Aspect;
      var slope = triangle.Slope;
      // get centroid
      var centroid = triangle.GetCentroid();
      // get normal
      var normal = triangle.GetNormal();
      // get adjacent triangles
      var adjTriangles = triangle.GetAdjacentTriangles();
      // get area of triangle that falls between the z values
      double minZ = 1.0;
      double maxZ = 3.0;
      IReadOnlyList<Coordinate3D> coords = triangle.GetPointsBetweenZs(minZ, maxZ);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
