ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / Length Property
Example
    Length Property (TinTriangle)
    Gets the length (i.e. perimeter) of this TIN triangle. The length is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides NotOverridable ReadOnly Property Length As Double
    public override double Length {get;}
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    TIN Triangles
      // nodes, edges of the triangle
      var triNnodes = triangle.Nodes;
      var triEdges = triangle.Edges;
      // triangle geometry
      polygon = triangle.ToPolygon();
      // triangle length
      var triLength = triangle.Length;
      // triangle area
      var triArea = triangle.Area;
      // is the triangle "inside"
      var isInsideTriangle = triangle.IsInsideDataArea;
      // triangle aspect and slope  (radians)
      var aspect = triangle.Aspect;
      var slope = triangle.Slope;
      // get centroid
      var centroid = triangle.GetCentroid();
      // get normal
      var normal = triangle.GetNormal();
      // get adjacent triangles
      var adjTriangles = triangle.GetAdjacentTriangles();
      // get area of triangle that falls between the z values
      double minZ = 1.0;
      double maxZ = 3.0;
      IReadOnlyList<Coordinate3D> coords = triangle.GetPointsBetweenZs(minZ, maxZ);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
