ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / Length3D Property
    Length3D Property (TinTriangle)
    Gets the 3D length (i.e. perimeter) of this TIN triangle. The length is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. If the triangle has NaN z-values, then NaN is returned. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property Length3D As Double
    public double Length3D {get;}
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
