ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / Slope Property
Example
    Slope Property (TinTriangle)
    Gets the slope of this TIN triangle in radians. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property Slope As Double
    public double Slope {get;}
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    Slope is the steepness of the triangle.
    Example
    TIN Triangles
      // nodes, edges of the triangle
      var triNnodes = triangle.Nodes;
      var triEdges = triangle.Edges;
      // triangle geometry
      polygon = triangle.ToPolygon();
      // triangle length
      var triLength = triangle.Length;
      // triangle area
      var triArea = triangle.Area;
      // is the triangle "inside"
      var isInsideTriangle = triangle.IsInsideDataArea;
      // triangle aspect and slope  (radians)
      var aspect = triangle.Aspect;
      var slope = triangle.Slope;
      // get centroid
      var centroid = triangle.GetCentroid();
      // get normal
      var normal = triangle.GetNormal();
      // get adjacent triangles
      var adjTriangles = triangle.GetAdjacentTriangles();
      // get area of triangle that falls between the z values
      double minZ = 1.0;
      double maxZ = 3.0;
      IReadOnlyList<Coordinate3D> coords = triangle.GetPointsBetweenZs(minZ, maxZ);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
