ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class / TagValue Property
    TagValue Property (TinTriangle)
    Gets the tag value of this TIN triangle. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides NotOverridable ReadOnly Property TagValue As Integer
    public override int TagValue {get;}
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    Tag values can be set to any value and their interpretation is left up to the user.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
