ArcGIS.Core.Data.Analyst3D Namespace / TinFilterType Enumeration
Example Example
    Filter types. Used in TinFilter.FilterType.
    Syntax
    Members
    MemberDescription
    All Filter for all elements in the TIN.
    InsideDataAreaFilter for all elements inside the TIN data area only. See TinDataset.GetDataArea.
    InsideTin Filter for all elements in the TIN except those associated to super nodes.
    Example
    Search for TIN Nodes
      // search all nodes that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorsearch = tinDataset.SearchNodes(null))
        while (nodeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinNode nodeCurrent = nodeCursor.Current)
            // do something with the node
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
      nodeFilter.FilterEnvelope = envelope; //or use any other appropriate envelope
      using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorSearch = tinDataset.SearchNodes(nodeFilter))
      // search all "inside" nodes
      nodeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for super nodes only
      nodeFilter.FilterEnvelope = tinDataset.GetSuperNodeExtent();
      nodeFilter.SuperNode = true;
    Search for TIN Edges
      // search all single edges that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(null))
        while (edgeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeCurrent = edgeCursor.Current)
            // do something with the edge
      ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
      edgeFilter.FilterEnvelope = envelope;
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(edgeFilter))
      // search all "inside" edges
      edgeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for hard edges
      edgeFilter.FilterByEdgeType = true;
      edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
    Search for TIN Triangles
      // search all triangles that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(null))
        while (triangleCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinTriangle triangleCurrent = triangleCursor.Current)
      ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
      triangleFilter.FilterEnvelope = envelope;
      using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(triangleFilter))
      // search all "inside" triangles
      triangleFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
    Requirements
    ArcGIS Pro version: 3.2 or higher.
