ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / TraceConfiguration Class / ValidateLocatability Property
    Specifies whether an error will be returned during a trace if nonspatial junction or edge objects are encountered without the necessary containment, attachment, or connectivity association in their association hierarchy of the traversed objects. This parameter ensures that nonspatial objects returned by a trace or update subnetwork operation can be located through an association with features or other locatable objects.
    Syntax
    Public Property ValidateLocatability As Boolean
    public bool ValidateLocatability {get; set;}
    Remarks
    • True : The trace will return an error if nonspatial junction or edge objects are encountered without the necessary containment, attachment, or connectivity association in their association hierarchy of the traversed objects.
    • False : The trace will not check for unlocatable objects and will return results regardless of whether unlocatable objects are present in the association hierarchy of the traversed objects. This is the default.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
