ArcGIS.Core.Geometry Namespace / Multipatch Class / To3DObjectXML Method
The 3D format to which this instance should be converted to. Supported values are: 3D_dae: Collada 3D_dwg: Autodesk DWG 3D_fbx: Autodesk FBX 3D_glb: Khronos Group glTF binary 3D_gltf: Khronos Group glTF JSON 3D_ifc: Industry Foundation Classes 3D_obj: Wavefront OBJ 3D_shapebuffer: Esri shape buffer 3D_usd: Universal Scene Description 3D_usda: Universal Scene Description(text) 3D_usdc: Universal Scene Description 3D_usdz: Universal Scene Description(zip) 3D_gml: CityGML any: return all assets as-is without any conversion
    Get a 3D object XML representation of this instance in the format provided.
    Syntax
    Public Function To3DObjectXML( _
       ByVal format As String _
    ) As String
    public string To3DObjectXML(
       string format
    Parameters
    format
    Return Value
    A XML document representing the 3D object with the asset(s) in the requested format or null if this MultiPatch does not have a 3D object handle.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
