ArcGIS.Desktop.Mapping Namespace / MapTool Class / ShowGroundToGridCorrections Property
    Gets or sets whether the ground to grid corrections heads-up display is shown when ground to grid is turned on in the UI. Default is false.
    Syntax
    Protected Property ShowGroundToGridCorrections As Boolean
    protected bool ShowGroundToGridCorrections {get; set;}
    Remarks
    The ground to grid heads-up display is shown for most COGO editing tools when the ground to grid corrections are turned on in the UI. Custom MapTools will not show this heads up display by default. Set this property to true for custom COGO tools that require the ground to grid correction settings.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
