ArcGIS.Desktop.Layouts Namespace / ILayoutPane Interface / LayoutView Property
Example
    LayoutView Property (ILayoutPane)
    Gets the layout view contained within the pane.
    Syntax
    ReadOnly Property LayoutView As LayoutView
    LayoutView LayoutView {get;}
    Example
    Activate an already open layout view
      //Activate an already open layout view.
      //A layout view may be open but it may not be active.
      //Find the pane that references the layout and activate it.
      //Note - there can be multiple panes referencing the same layout.
      foreach (var pane in ProApp.Panes)
        var layoutPane = pane as ILayoutPane;
        if (layoutPane == null)  //if not a layout view, continue to the next pane
          continue;
        if (layoutPane.LayoutView.Layout == layout) //activate the view
          (layoutPane as Pane).Activate();
          return;
    Requirements
