ArcGIS.Desktop.Layouts Namespace / GraphicElement Class / CanApplyStyle Method
The style item to check whether its styling can be applied
Example
    CanApplyStyle Method (GraphicElement)
    Gets whether the StyleItem can be applied
    Syntax
    Public Overrides Function CanApplyStyle( _
       ByVal styleItem As StyleItem _
    ) As Boolean
    public override bool CanApplyStyle(
       StyleItem styleItem
    Parameters
    styleItem
    Return Value
    Remarks
    Styles cannot be applied to CIMPictureGraphic. If the underlying graphic is null false will also be returned.
    Example
    Apply a style to a Graphic Element
      //Note: Run within QueuedTask context.
      //Get the Style project items in the project
      var styleProjectItems = Project.Current?.GetItems<StyleProjectItem>();
      //Get the ArcGIS 2D Style Project Item
      var styleProjectItem =
      styleProjectItems.OfType<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
      if (styleProjectItem == null) return;
      //Get the north arrow style item you need
      var pointStyleItem =
      styleProjectItem.SearchSymbols(StyleItemType.PointSymbol, "Circle 3").FirstOrDefault();
      if (pointStyleItem == null) return;
      //Select a North arrow layout element
      var layoutPointElement = layout.GetSelectedElements().FirstOrDefault();
      if (layoutPointElement != null && layoutPointElement is GraphicElement ge)
        if (layoutPointElement.CanApplyStyle(pointStyleItem))
          //The magic happens here
          //for Graphic Elements such as Point, Lines, Polys, text, preserve size.
          ge.ApplyStyle(pointStyleItem, true);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
