ArcGIS.Desktop.Mapping Namespace / JPEGFormat Class / GeoReferenceMapFrameName Property
Example
    GeoReferenceMapFrameName Property (JPEGFormat)
    Gets or sets the name of the map frame used to define the coordinate system for georeference information
    Syntax
    Public Property GeoReferenceMapFrameName As String
    public string GeoReferenceMapFrameName {get; set;}
    Remarks
    The default value is "".
    Example
    Export a map frame to JPG
      //Export a map frame to JPG.
      string filePath = @"Path and file name for the output export file";
      //Create JPEG format with appropriate settings
      //BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      JPEGFormat JPG = new JPEGFormat()
        HasWorldFile = true,
        Resolution = 300,
        OutputFileName = filePath,
        ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
        Height = 800,
        Width = 1200
      //Reference the map frame
      MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
      //Export on the worker thread
      //Note: Must be on QueuesTask.Run
      //Check to see if the path is valid and export
      if (JPG.ValidateOutputFilePath())
        mf.Export(JPG);  //Export the map frame to JPG
    Requirements
    ArcGIS Pro version: 3.2 or higher.
