public class JPEGFormat : ExportFormat
Public Class JPEGFormat Inherits ExportFormat
//Export a map frame to JPG.
string filePath = @"Path and file name for the output export file";
//Create JPEG format with appropriate settings
//BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
JPEGFormat JPG = new JPEGFormat()
HasWorldFile = true,
Resolution = 300,
OutputFileName = filePath,
ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
Height = 800,
Width = 1200
//Export on the worker thread
await QueuedTask.Run(() =>
//Reference the map frame
MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
//Check to see if the path is valid and export
if (JPG.ValidateOutputFilePath())
mf.Export(JPG); //Export the map frame to JPG
System.Object
ArcGIS.Desktop.Mapping.ExportFormat
ArcGIS.Desktop.Mapping.JPEGFormat
