ArcGIS.Desktop.Layouts Namespace / LayoutFactory Class / Instance Property
Example
    Instance Property (LayoutFactory)
    Gets the singleton instance for ILayoutFactory
    Syntax
    public static ILayoutFactory Instance {get;}
    Public Shared ReadOnly Property Instance As ILayoutFactory
    Example
    Create a new, basic layout and open it
      //Create a new, basic layout and open it.
      var myNewLayout = await QueuedTask.Run(() =>
        var newLayout = LayoutFactory.Instance.CreateLayout(8.5, 11, LinearUnit.Inches);
        newLayout.SetName("New 8.5x11 Layout");
        return newLayout;
      //Open new layout on the GUI thread
      await ProApp.Panes.CreateLayoutPaneAsync(myNewLayout);
    Create a new layout using a modified CIM and open it
      //Create a new layout using a modified CIM and open it.
      //The CIM exposes additional members that may not be
      //available through the managed API.
      //In this example, optional guides are added.
      //Set up a CIM page
      CIMPage newPage = new CIMPage
        //required parameters
        Width = 8.5,
        Height = 11,
        Units = LinearUnit.Inches,
        //optional rulers
        ShowRulers = true,
        SmallestRulerDivision = 0.5,
        //optional guides
        ShowGuides = true
      CIMGuide guide1 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Vertical
      CIMGuide guide2 = new CIMGuide
        Position = 6.5,
      CIMGuide guide3 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Horizontal
      CIMGuide guide4 = new CIMGuide
        Position = 10,
      List<CIMGuide> guideList = new List<CIMGuide>
        guide1,
        guide2,
        guide3,
        guide4
      newPage.Guides = guideList.ToArray();
      //Construct the new layout using the customized cim definitions
      var layout_local = await QueuedTask.Run(() =>
        var newLayout = LayoutFactory.Instance.CreateLayout(newPage);
        return newLayout;
      await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
    Requirements
