ArcGIS.Desktop.Mapping Namespace / ITablePane Interface / MapMember Property
Example
    MapMember Property (ITablePane)
    Gets the Layer or StandaloneTable source of the table.
    Syntax
    ReadOnly Property MapMember As MapMember
    MapMember MapMember {get;}
    Example
    Retrieve the values of selected cell in the attribute table
            if (FrameworkApplication.Panes.ActivePane is ITablePane tablePane)
                var mapMember = tablePane.MapMember;
                //Get the active row's object ID from the table pane
                var oid = tablePane.ActiveObjectID;
                if (oid.HasValue && oid.Value != -1 && mapMember != null)
                    //Get the field of the active column
                    var activeField = tablePane.ActiveColumn;
                    QueuedTask.Run(() =>
                        // TODO: Use core objects to retrieve record and get value
    Requirements
