The refraction option will compensate for the influence of atmospheric refraction, which forces light to bend as it passes through the atmosphere.
The amount of this deviation is controlled by variations in air pressure and density, humidity, temperature, and elevation.
It can only be used when the surface's spatial reference is in a projected coordinate system and z-coordinate units are defined.
Requirements
