ArcGIS.Desktop.Mapping Namespace / SurfaceLayer Class / RemoveRenderer Method
A SurfaceRendererTarget indicating the usage of the renderer.
Example
    Removes a surface layer's renderer that applies to the specified target. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void RemoveRenderer(
       SurfaceRendererTarget surfaceRendererTarget
    Public Sub RemoveRenderer( _
       ByVal surfaceRendererTarget As SurfaceRendererTarget _
    Parameters
    Exceptions
    ExceptionDescription
    Example
    Remove an edge renderer
      await QueuedTask.Run(() =>
        surfaceLayer.RemoveRenderer(SurfaceRendererTarget.Edges);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
