SurfaceRendererTarget Enumeration
Specifies a valid list of renderer categories that a
ArcGIS.Core.CIM.CIMTinRenderer might be applicable for. See
SurfaceLayer.CanSetRenderer and
SurfaceLayer.SetRenderer.
Create a TinLayer with renderers
var tinCP_renderers = new TinLayerCreationParams(tinDataset)
Name = "My TIN layer",
IsVisible = true
// define the node renderer - use defaults
var node_rd = new TinNodeRendererDefinition();
// define the face/surface renderer
var face_rd = new TinFaceClassBreaksRendererDefinition();
face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
// accept default color ramp, breakCount
// set up the renderer dictionary
var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
{ SurfaceRendererTarget.Points, node_rd },
{ SurfaceRendererTarget.Surface, face_rd }
// assign the dictionary to the creation params
tinCP_renderers.RendererDefinitions = rendererDict;
// Note: Needs QueuedTask to run
// create the layer
var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
Create a TerrainLayer with renderers
var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
terrainCP_renderers.Name = "My LAS Layer";
terrainCP_renderers.IsVisible = true;
// define the edge type renderer - use defaults
var edgeRD = new TinBreaklineRendererDefinition();
var faceRD = new TinFaceClassBreaksRendererDefinition();
faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
// define the dirty area renderer - use defaults
var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
// add renderers to dictionary
var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
// assign dictionary to creation params
terrainCP_renderers.RendererDefinitions = t_dict;
//Create the layer to the terrain
var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
Create a LasDatasetLayer with renderers
var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
lasCP_renderers.Name = "My LAS Layer";
lasCP_renderers.IsVisible = false;
// create a point elevation renderer
var ptR = new LasStretchRendererDefinition();
// accept all defaults
// create a simple edge renderer
var edgeR = new TinEdgeRendererDefintion();
var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
l_dict.Add(SurfaceRendererTarget.Points, ptR);
l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
lasCP_renderers.RendererDefinitions = l_dict;
//Create the layer to the LAS dataset
var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
Get Renderers
// get the list of renderers
IReadOnlyList<CIMTinRenderer> renderers = surfaceLayer.GetRenderers();
// get the renderers as a dictionary
Dictionary<SurfaceRendererTarget, CIMTinRenderer> dict = surfaceLayer.GetRenderersAsDictionary();
Simple Node Renderer
// applies to TIN layers only
var nodeRendererDef = new TinNodeRendererDefinition();
nodeRendererDef.Description = "Nodes";
nodeRendererDef.Label = "Nodes";
nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
if (tinLayer.CanCreateRenderer(nodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
Elevation Node Renderer - Equal Breaks
var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
equalBreaksNodeRendererDef.BreakCount = 7;
if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
Elevation Node Renderer - Defined Interval
var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
defiendIntervalNodeRendererDef.IntervalSize = 4;
defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
Elevation Node Renderer - Standard Deviation
var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
Simple Edge Renderer
// applies to TIN or LAS dataset layers only
var edgeRendererDef = new TinEdgeRendererDefintion();
edgeRendererDef.Description = "Edges";
edgeRendererDef.Label = "Edges";
edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
Edge Type Renderer
var breaklineRendererDef = new TinBreaklineRendererDefinition();
// use default symbol for regular edge but specific symbols for hard,soft,outside
breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
Contour Renderer
var contourDef = new TinContourRendererDefinition();
// now customize with a symbol
contourDef.Label = "Contours";
contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
contourDef.ContourInterval = 6;
contourDef.IndexLabel = "Index Contours";
contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
contourDef.ContourFactor = 4;
contourDef.ReferenceHeight = 7;
if (surfaceLayer.CanCreateRenderer(contourDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
Simple Face Renderer
var simpleFaceRendererDef = new TinFaceRendererDefinition();
simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
Aspect Face Renderer
var aspectFaceRendererDef = new TinFaceClassBreaksAspectRendererDefinition();
aspectFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(aspectFaceRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(aspectFaceRendererDef);
Slope Face Renderer - Equal Interval
var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
// accept default breakCount, symbolTemplate, color ramp
if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
Slope Face Renderer - Quantile
var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
Elevation Face Renderer - Equal Interval
var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
Dirty Area Renderer
var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
// accept default labels, symbolTemplate
if (terrainLayer == null)
return;
if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
Terrain Point Class Breaks Renderer
var terrainPointClassBreaks = new TerrainPointClassBreaksRendererDefinition();
// accept defaults
if (terrainLayer.CanCreateRenderer(terrainPointClassBreaks))
CIMTinRenderer renderer = terrainLayer.CreateRenderer(terrainPointClassBreaks);
if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
LAS Points Classification Unique Value Renderer
var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
// accept the defaults for color ramp, symbolTemplate, symbol scale factor
if (lasDatasetLayer == null)
return;
if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
LAS Points Returns Unique Value Renderer
var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
LAS Points Elevation Stretch Renderer
var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
// accept the defaults for color ramp, etc
if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
// OR use a stretch renderer with stretchType standard Deviations
var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
LAS Points Classified Elevation Renderer
var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
// increase the symbol size by a factor
lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
Remove an edge renderer
surfaceLayer.RemoveRenderer(SurfaceRendererTarget.Edges);
System.Object
System.ValueType
System.Enum
ArcGIS.Desktop.Mapping.SurfaceRendererTarget
ArcGIS Pro version: 3.2 or higher.
