ArcGIS.Desktop.Mapping Namespace / SurfaceLayer Class / CanSetRenderer Method
A custom renderer that will be used to draw the surface layer.
A SurfaceRendererTarget indicating the intended usage of the renderer.
Example
    CanSetRenderer Method (SurfaceLayer)
    Determines whether a renderer is valid and can be applied for the surface layer and target, This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    renderer
    surfaceRendererTarget
    Return Value
    A boolean indicates that the renderer can be applied to the layer.
    Exceptions
    ExceptionDescription
    Remarks
    It is important to call this method prior to SetRenderer as some renderers are only appropriate for certain layer types and can only be applied for a specified SurfaceRendererTarget. For example a ArcGIS.Core.CIM.CIMTinNodeRenderer applies only to a TIN layer and can only be set to a target of SurfaceRendererTarget.Points.
    Example
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
      await QueuedTask.Run(() =>
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Elevation Node Renderer - Equal Breaks
      var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      equalBreaksNodeRendererDef.BreakCount = 7;
        if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Elevation Node Renderer - Defined Interval
      var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
      defiendIntervalNodeRendererDef.IntervalSize = 4;
      defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
    Elevation Node Renderer - Standard Deviation
      var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
      stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
      stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
        if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Edge Type Renderer
      var breaklineRendererDef = new TinBreaklineRendererDefinition();
      // use default symbol for regular edge but specific symbols for hard,soft,outside
      breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
    Contour Renderer
      var contourDef = new TinContourRendererDefinition();
      // now customize with a symbol
      contourDef.Label = "Contours";
      contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
      contourDef.ContourInterval = 6;
      contourDef.IndexLabel = "Index Contours";
      contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
      contourDef.ContourFactor = 4;
      contourDef.ReferenceHeight = 7;
        if (surfaceLayer.CanCreateRenderer(contourDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
    Simple Face Renderer
      var simpleFaceRendererDef = new TinFaceRendererDefinition();
      simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
    Aspect Face Renderer
      var aspectFaceRendererDef = new TinFaceClassBreaksAspectRendererDefinition();
      aspectFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
      // accept default color ramp
        if (surfaceLayer.CanCreateRenderer(aspectFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(aspectFaceRendererDef);
    Slope Face Renderer - Equal Interval
      var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      // accept default breakCount, symbolTemplate, color ramp
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
    Slope Face Renderer - Quantile
      var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
    Elevation Face Renderer - Equal Interval
      var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
        if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
    Dirty Area Renderer
      var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
      // accept default labels, symbolTemplate
      if (terrainLayer == null)
        return;
        if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
          CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
          if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
            terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
    Terrain Point Class Breaks Renderer
      var terrainPointClassBreaks = new TerrainPointClassBreaksRendererDefinition();
      // accept defaults
        if (terrainLayer.CanCreateRenderer(terrainPointClassBreaks))
          CIMTinRenderer renderer = terrainLayer.CreateRenderer(terrainPointClassBreaks);
          if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Classification Unique Value Renderer
      var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
      // accept the defaults for color ramp, symbolTemplate, symbol scale factor
      if (lasDatasetLayer == null)
        return;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Returns Unique Value Renderer
      var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
      lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
      lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
