Parameters
- cimPage
- CIMPage
Return Value
Returns Layout or a null.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run. |
//Create a new layout using a modified CIM and open it.
//The CIM exposes additional members that may not be
//available through the managed API.
//In this example, optional guides are added.
//Create a new CIMLayout on the worker thread
//Note: Needs QueuedTask to run
//Set up a CIM page
CIMPage newPage = new CIMPage
//required parameters
Width = 8.5,
Height = 11,
Units = LinearUnit.Inches,
//optional rulers
ShowRulers = true,
SmallestRulerDivision = 0.5,
//optional guides
ShowGuides = true
CIMGuide guide1 = new CIMGuide
Position = 1,
Orientation = Orientation.Vertical
CIMGuide guide2 = new CIMGuide
Position = 6.5,
CIMGuide guide3 = new CIMGuide
Position = 1,
Orientation = Orientation.Horizontal
CIMGuide guide4 = new CIMGuide
Position = 10,
List<CIMGuide> guideList = new List<CIMGuide>
guide1,
guide2,
guide3,
guide4
newPage.Guides = guideList.ToArray();
//Construct the new layout using the customized cim definitions
var layout_local = LayoutFactory.Instance.CreateLayout(newPage);
layout_local.SetName("New 8.5x11 Layout");
//Open new layout on the GUI thread
await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
//Change the layout page size.
//Reference the layout project item
LayoutProjectItem lytItem = Project.Current.GetItems<LayoutProjectItem>()
.FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
if (layoutItem != null)
//Get the layout
Layout lyt = lytItem.GetLayout();
if (lyt != null)
//Change properties
CIMPage page = lyt.GetPage();
page.Width = 8.5;
page.Height = 11;
//Apply the changes to the layout
lyt.SetPage(page);
