ArcGIS.Core.Data.UtilityNetwork Namespace / Terminal Class / Equals Method / Equals(Terminal) Method
An object to compare.
    Determines if the given object is identical to this object.
    Syntax
    Public Overloads Function Equals( _
       ByVal other As Terminal _
    ) As Boolean
    public bool Equals(
       Terminal other
    Parameters
    other
    Return Value
    Returns true if objects are equal, false otherwise.
    Requirements
