ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / FunctionOutput Class
Members Example
    The result of a Function that is executed by a trace.
    Object Model
    FunctionOutput ClassFunction Class
    Syntax
    Public Class FunctionOutput
    public class FunctionOutput
    Example
    Using Function Results
      // This routine demonstrates how to extract function results from trace results
      static void UseFunctionResults(IReadOnlyList<Result> traceResults)
        // Get the FunctionOutputResult from the trace results
        FunctionOutputResult functionOutputResult = traceResults.OfType<FunctionOutputResult>().First();
        // First() can be used here if only one Function was included in the TraceConfiguration.Functions collection.
        // Otherwise you will have to search the list for the correct FunctionOutput object.
        FunctionOutput functionOutput = functionOutputResult.FunctionOutputs.First();
        // Extract the total load from the GlobalValue property
        double totalLoad = (double)functionOutput.Value;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.UtilityNetwork.Trace.FunctionOutput
    Requirements
