ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / FunctionOutput Class / Value Property
Example
    Value Property (FunctionOutput)
    The global result of the function.
    Syntax
    Public ReadOnly Property Value As Object
    public object Value {get;}
    Remarks
    For example, if the Function was Add, this is the sum for every feature returned by the trace.
    Example
    Using Function Results
      // This routine demonstrates how to extract function results from trace results
      static void UseFunctionResults(IReadOnlyList<Result> traceResults)
        // Get the FunctionOutputResult from the trace results
        FunctionOutputResult functionOutputResult = traceResults.OfType<FunctionOutputResult>().First();
        // First() can be used here if only one Function was included in the TraceConfiguration.Functions collection.
        // Otherwise you will have to search the list for the correct FunctionOutput object.
        FunctionOutput functionOutput = functionOutputResult.FunctionOutputs.First();
        // Extract the total load from the GlobalValue property
        double totalLoad = (double)functionOutput.Value;
    Requirements
