ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / Result Class
Members Example
    Result Class
    The Result object returns information from a trace.
    Syntax
    Public MustInherit Class Result
    public abstract class Result
    Example
    Trace a utility network using a named trace configuration
      // This routine demonstrates how to perform a trace using a named trace configuration from a utility network
      static void TraceUtilityNetworkUsingNamedTraceConfiguration(UtilityNetwork utilityNetwork, NamedTraceConfiguration namedTraceConfiguration, Element startElement)
        // Get the trace manager from the utility network
        using (TraceManager traceManager = utilityNetwork.GetTraceManager())
          // Get a tracer from the trace manager using the named trace configuration
          Tracer upstreamTracer = traceManager.GetTracer(namedTraceConfiguration);
          // Trace argument holding the trace input parameters
          TraceArgument upstreamTraceArgument = new TraceArgument(namedTraceConfiguration, new List<Element> { startElement });
          // Trace results
          IReadOnlyList<Result> upstreamTraceResults = upstreamTracer.Trace(upstreamTraceArgument);
    Inheritance Hierarchy
    Requirements
