ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / TraceArgument Class / TraceArgument Constructor / TraceArgument Constructor(Subnetwork)
The Subnetwork whose controllers are used as starting points for the trace.
Example
    Initializes a new instance of the TraceArgument class using a subnetwork.
    Syntax
    Public Function New( _
       ByVal subnetwork As Subnetwork _
    public TraceArgument(
       Subnetwork subnetwork
    Parameters
    subnetwork
    Exceptions
    ExceptionDescription
    subnetwork is null.
    Remarks
    This constructor is only supported by SubnetworkTracer.
    Example
    Create a Trace Argument
      // This routine creates a TraceArgument object and assigns a TraceConfiguration to it
      static void CreateTraceArgument()
        IReadOnlyList<Element> startingPointList = new List<Element>();
        // Code to fill in list of starting points goes here...
        TraceArgument traceArgument = new TraceArgument(startingPointList);
        TraceConfiguration traceConfiguration = new TraceConfiguration();
        // Code to fill in trace configuration goes here...
        traceArgument.Configuration = traceConfiguration;
    Trace a utility network with the digitized direction
      // This routine demonstrates how to perform a trace using the digitized direction of features
      static void TraceWithDigitizedDirection(UtilityNetwork utilityNetwork, Element startElement)
        using TraceManager traceManager = utilityNetwork.GetTraceManager();
        // Trace configuration with digitized direction
          IncludeIsolatedFeatures = true,
          IncludeBarriersWithResults = true,
          UseDigitizedDirection = true
        // Trace argument
        List<Element> startElements = new List<Element> { startElement };
        TraceArgument traceArgument = new TraceArgument(startElements);
        // Results
        DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
        IReadOnlyList<Result> traceResults = downstreamTracer.Trace(traceArgument);
        foreach (Result traceResult in traceResults)
          // Iterate trace results
    Trace a utility network using a named trace configuration
      // This routine demonstrates how to perform a trace using a named trace configuration from a utility network
      static void TraceUtilityNetworkUsingNamedTraceConfiguration(UtilityNetwork utilityNetwork, NamedTraceConfiguration namedTraceConfiguration, Element startElement)
        // Get the trace manager from the utility network
        using (TraceManager traceManager = utilityNetwork.GetTraceManager())
          // Get a tracer from the trace manager using the named trace configuration
          Tracer upstreamTracer = traceManager.GetTracer(namedTraceConfiguration);
          // Trace argument holding the trace input parameters
          TraceArgument upstreamTraceArgument = new TraceArgument(namedTraceConfiguration, new List<Element> { startElement });
          // Trace results
          IReadOnlyList<Result> upstreamTraceResults = upstreamTracer.Trace(upstreamTraceArgument);
    Requirements
