Public Function GetTinDataset() As TinDataset
public TinDataset GetTinDataset()
Return Value
The TIN dataset associated with the layer.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
using statement or a finally block.{
//Note: Needs QueuedTask to run
using (var tin = tinLayer.GetTinDataset())
using var tinDef = tin.GetDefinition();
Envelope extent = tinDef.GetExtent();
SpatialReference sr = tinDef.GetSpatialReference();
using (terrain = terrainLayer.GetTerrain())
using var terrainDef = terrain.GetDefinition();
Envelope extent = terrainDef.GetExtent();
SpatialReference sr = terrainDef.GetSpatialReference();
using (lasDataset = lasDatasetLayer.GetLasDataset())
using var lasDatasetDef = lasDataset.GetDefinition();
Envelope extent = lasDatasetDef.GetExtent();
SpatialReference sr = lasDatasetDef.GetSpatialReference();
