ArcGIS.Desktop.Mapping Namespace / TinLayer Class
Members Example
    TinLayer Class
    Represents a TIN layer.
    Object Model
    TinLayer ClassCIMTinRenderer ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassElevationTypeDefinition ClassLineOfSightResult ClassSpatialReference ClassSurfaceValues ClassTimeParameters ClassTinDataset ClassSurfaceZsResult ClassMultipatch ClassGeometry ClassGeometry ClassMap ClassILayerContainer InterfaceEnvelope ClassTinEdgeCursor ClassTinNodeCursor ClassTinTriangleCursor Class
    Syntax
    Example
    Retrieve layers
      // find the first TIN layer
      tinLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
      // find the first Terrain layer
      terrainLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<TerrainLayer>().FirstOrDefault();
      // find the first LAS dataset layer
      lasDatasetLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<LasDatasetLayer>().FirstOrDefault();
      // find the first surface layer
      surfaceLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<SurfaceLayer>().FirstOrDefault();
    Create a TinLayer
      string tinPath = @"d:\Data\Tin\TinDataset";
      var tinURI = new Uri(tinPath);
      var tinCP = new TinLayerCreationParams(tinURI);
      tinCP.Name = "My TIN Layer";
      tinCP.IsVisible = false;
      // Note: Needs QueuedTask to run
        //Create the layer to the TIN
        tinLayer = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP, map);
    Create a TinLayer from a dataset
      var tinCP_ds = new TinLayerCreationParams(tinDataset);
      tinCP_ds.Name = "My TIN Layer";
      tinCP_ds.IsVisible = false;
        var tinLayer_ds = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_ds, map);
    Create a TinLayer with renderers
      var tinCP_renderers = new TinLayerCreationParams(tinDataset)
        Name = "My TIN layer",
        IsVisible = true
      // define the node renderer - use defaults
      var node_rd = new TinNodeRendererDefinition();
      // define the face/surface renderer
      var face_rd = new TinFaceClassBreaksRendererDefinition();
      face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // set up the renderer dictionary
      var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
      { SurfaceRendererTarget.Points, node_rd },
      { SurfaceRendererTarget.Surface, face_rd }
      // assign the dictionary to the creation params
      tinCP_renderers.RendererDefinitions = rendererDict;
        // create the layer
        var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.SurfaceLayer
                   ArcGIS.Desktop.Mapping.TinLayer
    Requirements
    ArcGIS Pro version: 3.2 or higher.
