Public NotInheritable Class ProjectWindowSelectedItemsChangedEvent Inherits ArcGIS.Core.Events.CompositePresentationEvent(Of ProjectWindowSelectedItemsChangedEventArgs)
public sealed class ProjectWindowSelectedItemsChangedEvent : ArcGIS.Core.Events.CompositePresentationEvent<ProjectWindowSelectedItemsChangedEventArgs>
// subscribe to event
ProjectWindowSelectedItemsChangedEvent.Subscribe(args =>
if (args.IProjectWindow.SelectionCount > 0)
// get the first selected item
var selectedItem = args.IProjectWindow.SelectedItems.First();
// Note: Needs QueuedTask to run
// datasetType
var dataType = ItemFactory.Instance.GetDatasetType(selectedItem);
// get the dataset Definition
if (ItemFactory.Instance.CanGetDefinition(selectedItem))
using var def = ItemFactory.Instance.GetDefinition(selectedItem);
if (def is FeatureClassDefinition fcDef)
var oidField = fcDef.GetObjectIDField();
var shapeField = fcDef.GetShapeField();
var shapeType = fcDef.GetShapeType();
else if (def is ArcGIS.Core.Data.Parcels.ParcelFabricDefinition pfDef)
string ver = pfDef.GetSchemaVersion();
bool enabled = pfDef.GetTopologyEnabled();
// get the dataset
if (ItemFactory.Instance.CanGetDataset(selectedItem))
using var ds = ItemFactory.Instance.GetDataset(selectedItem);
if (ds is FeatureDataset fds)
// open featureclasses within the feature dataset
// var fcPoint = fds.OpenDataset<FeatureClass>("Point");
// var fcPolyline = fds.OpenDataset<FeatureClass>("Polyline");
else if (ds is FeatureClass fc)
var name = fc.GetName() + "_copy";
// create
var featureLayerParams = new FeatureLayerCreationParams(fc)
Name = name,
MapMemberIndex = 0
LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerParams, MapView.Active.Map);
else if (ds is Table table)
var name = table.GetName() + "_copy";
var tableParams = new StandaloneTableCreationParams(table)
Name = name
// create
StandaloneTableFactory.Instance.CreateStandaloneTable(tableParams, MapView.Active.Map);
System.Object
ArcGIS.Core.Events.EventBase
ArcGIS.Core.Events.CompositePresentationEvent<TPayload>
ArcGIS.Desktop.Core.Events.ProjectWindowSelectedItemsChangedEvent
