ArcGIS.Desktop.Mapping Namespace / TinSimpleRendererDefinition Class / Description Property
Example
    Description Property (TinSimpleRendererDefinition)
    Gets or sets the description.
    Syntax
    Public Property Description As String
    public string Description {get; set;}
    Example
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
      // Note: Needs QueuedTask to run
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
