ArcGIS.Desktop.Mapping Namespace / TinSimpleRendererDefinition Class
Members Example
    Represents an abstract simple renderer definition to draw all objects in a surface layer with a common symbol.
    Object Model
    TinSimpleRendererDefinition ClassCIMSymbolReference Class
    Syntax
    Public MustInherit Class TinSimpleRendererDefinition
       Inherits TinRendererDefinition
    public abstract class TinSimpleRendererDefinition : TinRendererDefinition
    Remarks
    Once you define a simple renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
      // Note: Needs QueuedTask to run
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Inheritance Hierarchy
    Requirements
    ArcGIS Pro version: 3.2 or higher.
