ArcGIS.Desktop.Mapping Namespace / SurfaceLayer Class / CanCreateRenderer Method
A renderer definition object.
Example
    CanCreateRenderer Method (SurfaceLayer)
    Determines whether a renderer can be created and is valid for the surface layer using the specified TinRendererDefinition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool CanCreateRenderer(
       TinRendererDefinition rendererDefinition
    Public Function CanCreateRenderer( _
       ByVal rendererDefinition As TinRendererDefinition _
    ) As Boolean
    Parameters
    rendererDefinition
    Return Value
    A boolean indicates that a renderer can be created for the layer.
    Exceptions
    ExceptionDescription
    Remarks
    It is important to call this method prior to CreateRenderer as some renderers are only appropriate for certain layer types or for displaying features of a certain geometry type. For example a TinNodeRendererDefinition can only be applied to a TIN layer. It cannot be applied to a Terrain layer or a LAS dataset layer.
    Example
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
      await QueuedTask.Run(() =>
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Elevation Node Renderer - Equal Breaks
      var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      equalBreaksNodeRendererDef.BreakCount = 7;
        if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Elevation Node Renderer - Defined Interval
      var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
      defiendIntervalNodeRendererDef.IntervalSize = 4;
      defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
    Elevation Node Renderer - Standard Deviation
      var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
      stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
      stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
      stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
        if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Edge Type Renderer
      var breaklineRendererDef = new TinBreaklineRendererDefinition();
      // use default symbol for regular edge but specific symbols for hard,soft,outside
      breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
    Contour Renderer
      var contourDef = new TinContourRendererDefinition();
      // now customize with a symbol
      contourDef.Label = "Contours";
      contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
      contourDef.ContourInterval = 6;
      contourDef.IndexLabel = "Index Contours";
      contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
      contourDef.ContourFactor = 4;
      contourDef.ReferenceHeight = 7;
        if (surfaceLayer.CanCreateRenderer(contourDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
    Simple Face Renderer
      var simpleFaceRendererDef = new TinFaceRendererDefinition();
      simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
    Aspect Face Renderer
      var aspectFaceRendererDef = new TinFaceClassBreaksAspectRendererDefinition();
      aspectFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
      // accept default color ramp
        if (surfaceLayer.CanCreateRenderer(aspectFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(aspectFaceRendererDef);
    Slope Face Renderer - Equal Interval
      var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      // accept default breakCount, symbolTemplate, color ramp
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
    Slope Face Renderer - Quantile
      var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
    Elevation Face Renderer - Equal Interval
      var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
        if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
    Dirty Area Renderer
      var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
      // accept default labels, symbolTemplate
      if (terrainLayer == null)
        return;
        if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
          CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
          if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
            terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
    Terrain Point Class Breaks Renderer
      var terrainPointClassBreaks = new TerrainPointClassBreaksRendererDefinition();
      // accept defaults
        if (terrainLayer.CanCreateRenderer(terrainPointClassBreaks))
          CIMTinRenderer renderer = terrainLayer.CreateRenderer(terrainPointClassBreaks);
          if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Classification Unique Value Renderer
      var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
      // accept the defaults for color ramp, symbolTemplate, symbol scale factor
      if (lasDatasetLayer == null)
        return;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Returns Unique Value Renderer
      var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
      lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
      lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
