Public Function CreateRenderer( _ ByVal rendererDefinition As TinRendererDefinition _ ) As CIMTinRenderer
public CIMTinRenderer CreateRenderer( TinRendererDefinition rendererDefinition )
Parameters
- rendererDefinition
- A renderer definition object.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentException | Cannot create renderer for layer. The renderer definition is invalid. |
| System.Exception | Failed to create renderer. There was a processing error. |
// applies to TIN layers only
var nodeRendererDef = new TinNodeRendererDefinition();
nodeRendererDef.Description = "Nodes";
nodeRendererDef.Label = "Nodes";
nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
// Note: Needs QueuedTask to run
if (tinLayer.CanCreateRenderer(nodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
equalBreaksNodeRendererDef.BreakCount = 7;
if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
defiendIntervalNodeRendererDef.IntervalSize = 4;
defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
// applies to TIN or LAS dataset layers only
var edgeRendererDef = new TinEdgeRendererDefintion();
edgeRendererDef.Description = "Edges";
edgeRendererDef.Label = "Edges";
edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
var breaklineRendererDef = new TinBreaklineRendererDefinition();
// use default symbol for regular edge but specific symbols for hard,soft,outside
breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
var contourDef = new TinContourRendererDefinition();
// now customize with a symbol
contourDef.Label = "Contours";
contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
contourDef.ContourInterval = 6;
contourDef.IndexLabel = "Index Contours";
contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
contourDef.ContourFactor = 4;
contourDef.ReferenceHeight = 7;
if (surfaceLayer.CanCreateRenderer(contourDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
var simpleFaceRendererDef = new TinFaceRendererDefinition();
simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
var aspectFaceRendererDef = new TinFaceClassBreaksAspectRendererDefinition();
aspectFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
// accept default color ramp
if (surfaceLayer.CanCreateRenderer(aspectFaceRendererDef))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(aspectFaceRendererDef);
var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
// accept default breakCount, symbolTemplate, color ramp
if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
// accept default labels, symbolTemplate
if (terrainLayer == null)
return;
if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
var terrainPointClassBreaks = new TerrainPointClassBreaksRendererDefinition();
// accept defaults
if (terrainLayer.CanCreateRenderer(terrainPointClassBreaks))
CIMTinRenderer renderer = terrainLayer.CreateRenderer(terrainPointClassBreaks);
if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
// accept the defaults for color ramp, symbolTemplate, symbol scale factor
if (lasDatasetLayer == null)
return;
if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
// accept the defaults for color ramp, etc
if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
// OR use a stretch renderer with stretchType standard Deviations
var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
// increase the symbol size by a factor
lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
