ArcGIS.Desktop.Mapping Namespace / TinSimpleRendererDefinition Class / Label Property
Example
    Label Property (TinSimpleRendererDefinition)
    Gets or sets the label that will show up on the TOC next to the symbol.
    Syntax
    Public Property Label As String
    public string Label {get; set;}
    Example
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
      // Note: Needs QueuedTask to run
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
