ArcGIS.Desktop.Mapping.Geocoding Namespace / LocatorManager Class / GeocodeAsync Method / GeocodeAsync(String,Boolean,Boolean) Method
The address/location to geocode.
Should the candidate results be displayed on the active map?
Should the map zoom to the first candidate result?
    Perform a geocode operation. Geocode results are returned according to the active locator providers.
    Syntax
    Parameters
    location
    showResultsOnMap
    zoomToFirstResult
    Return Value
    Task of List of GeocodeResult objects. If no locators can be found then null is returned.
    Remarks
    As the method is asynchronous, if multiple Geocodes are executed - one after the other, then a successive Geocode may be initiated before the prior Geocode has completed. In this case, a message box will be shown that must be acknowledged by the user to either cancel or continue the current geocode. Refer to GeocodeAsync(String,Boolean,Boolean,Boolean) to hide the message box/cancel prompt.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
