ArcGIS.Desktop.Workflow.Client.Models Namespace / IJobsManager Interface / FinishSteps Method
Example
    FinishSteps Method
    Finishes running the steps in the array, and proceeds to the next step(s). This method must be called on the MCT. Use QueuedTask.Run. If no stepIds are specified, then all the current steps will be finished.
    Syntax
    Sub FinishSteps( _
       ByVal jobId As String, _
       Optional ByVal stepIds As List(Of String) _
    void FinishSteps(
       string jobId,
       List<string> stepIds
    Parameters
    jobId
    stepIds
    Example
    QueuedTask.Run(() => { var id = WorkflowClientModule.JobsManager.GetJobId(); var stepIds = new List() { "123456789", "234567890" }; WorkflowClientModule.JobsManager.FinishSteps(id, stepIds); });
    Finish steps on a job
      var jobManager = WorkflowClientModule.JobsManager;
      // Finish the current steps in the job with the given id.
      jobManager.FinishSteps(jobId);
    Finish specific steps on a job
      List<string> stepIds = ["step12345", "step67890"];
      jobManager.FinishSteps(jobId, stepIds);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
