ArcGIS.Desktop.Workflow.Client.Models Namespace / IJobsManager Interface / StopSteps Method
Example
    StopSteps Method
    Stops running the steps in the array. Each step can be Run again or Finish can be used to complete them. In case of GP step and question step, the processing of each step is cancelled. In case of manual and open app step, each step is paused. Each step can be forced to stop by a user not assigned to the step with the jobForceStop privilege. This method must be called on the MCT. Use QueuedTask.Run. If no stepIds are specified, then all the current steps will be stopped.
    Syntax
    Sub StopSteps( _
       ByVal jobId As String, _
       Optional ByVal stepIds As List(Of String) _
    void StopSteps(
       string jobId,
       List<string> stepIds
    Parameters
    jobId
    stepIds
    Example
    QueuedTask.Run(() => { var id = WorkflowClientModule.JobsManager.GetJobId(); var stepIds = new List() { "123456789", "234567890" }; WorkflowClientModule.JobsManager.StopSteps(id, stepIds); });
    Stop running steps on a job
      var jobManager = WorkflowClientModule.JobsManager;
      // Get the job Id associated with the active map view
      jobId = jobManager.GetJobId();
      // Stop the current steps in the job with the given id.
      jobManager.StopSteps(jobId);
    Stop specific running steps on a job
      // Specify specific running steps in a job to stop
      List<string> stepIds = ["step12345", "step67890"];
      jobManager.StopSteps(jobId, stepIds);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
