ArcGIS.Desktop.Core Namespace / LayoutFrameworkExtender Class / CreateLayoutPaneAsync Method
Does not need to be specified.
Layout
Example
    Create and activate a new layout pane using a Layout reference. Must be called on GUI thread.
    Syntax
    Public Shared Function CreateLayoutPaneAsync( _
       ByVal paneCollection As PaneCollection, _
       ByVal layout As Layout _
    ) As Task(Of ILayoutPane)
    public static Task<ILayoutPane> CreateLayoutPaneAsync(
       PaneCollection paneCollection,
       Layout layout
    Parameters
    paneCollection
    layout
    Layout
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    Be sure to call this on the GUI thread. Do not execute within a QueuedTask.Run block.
    Example
    Open a layout project item in a new view
      //Open a layout project item in a new view.
      //A layout project item may exist but it may not be open in a view.
      //Reference a layout project item by name
      LayoutProjectItem layoutItemByName = Project.Current.GetItems<LayoutProjectItem>()
                                .FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
      //Get the layout associated with the layout project item
      //Note: Needs QueuedTask to run
      Layout layoutFromItem = layoutItemByName.GetLayout();  //Worker thread
      //Create the new pane - call on UI
      ILayoutPane iNewLayoutPane = await ProApp.Panes.CreateLayoutPaneAsync(layout); //GUI thread
    Create a new, basic layout and open it
      //Create a new, basic layout and open it.
      //Create layout with minimum set of parameters on the worker thread
      var myNewLayout = LayoutFactory.Instance.CreateLayout(8.5, 11, LinearUnit.Inches);
      myNewLayout.SetName("New 8.5x11 Layout");
      //Open new layout on the GUI thread
      await ProApp.Panes.CreateLayoutPaneAsync(myNewLayout);
    Create a new layout using a modified CIM and open it
      //Create a new layout using a modified CIM and open it.
      //The CIM exposes additional members that may not be
      //available through the managed API.
      //In this example, optional guides are added.
      //Create a new CIMLayout on the worker thread
      //Set up a CIM page
      CIMPage newPage = new CIMPage
        //required parameters
        Width = 8.5,
        Height = 11,
        Units = LinearUnit.Inches,
        //optional rulers
        ShowRulers = true,
        SmallestRulerDivision = 0.5,
        //optional guides
        ShowGuides = true
      CIMGuide guide1 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Vertical
      CIMGuide guide2 = new CIMGuide
        Position = 6.5,
      CIMGuide guide3 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Horizontal
      CIMGuide guide4 = new CIMGuide
        Position = 10,
      List<CIMGuide> guideList = new List<CIMGuide>
        guide1,
        guide2,
        guide3,
        guide4
      newPage.Guides = guideList.ToArray();
      //Construct the new layout using the customized cim definitions
      var layout_local = LayoutFactory.Instance.CreateLayout(newPage);
      layout_local.SetName("New 8.5x11 Layout");
      await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
    Requirements
