ArcGIS.Core.CIM Namespace / CIMMargin Class / Bottom Property
Example
    Bottom Property (CIMMargin)
    Gets or sets the bottom margin.
    Syntax
    Public Property Bottom As Double
    public double Bottom {get; set;}
    Example
    Presentation page design
      // create customized margin and color
      CIMMargin pMargin = new CIMMargin() { Left = 0.2, Right = 0.3, Top = 0.15, Bottom = 0.25 };
      CIMRGBColor pColor = new CIMRGBColor() { R = 255, G = 255, B = 0, Alpha = 50 };
      //Reference a page and its transition
      var pageReference = activePresentationView.Presentation.GetPage(0);
      CIMPresentationTransition transition = page.Transition;
      // update the transition style
      transition.TransitionType = PresentationTransitionType.Swipe;
      transition.Duration = 2.0;
      transition.SwipeDirection = SwipeDirection.Top;
      //Must be on the QueuedTask
      //Set the new margin, new background color and new transition effect
      page.SetMargin(pMargin);
      page.SetBackgroundColor(pColor);
      page.SetTransition(transition);
    Create report
      //Note: Call within QueuedTask.Run()
      //The fields in the datasource used for the report
      //This uses a US Cities dataset
      var listFields = new List<CIMReportField> {
              //Grouping should be the first field
              new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
              new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
              new CIMReportField{Name = "POP1990", FieldOrder = 2, },
      //Definition query to use for the data source
      var defQuery = "STATE_NAME LIKE 'C%'";
      //Define the Datasource
      var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
      //The CIMPage defintion - page size, units, etc
      var cimReportPage = new CIMPage
        Height = 11,
        StretchElements = false,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
        Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
        Units = LinearUnit.Inches
      //Report template
      var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
      var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
      //Report Styling
      var reportStyles = await ReportStylingManager.GetStylingsAsync();
      var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
      //Field Statistics
      var fieldStatisticsList = new List<ReportFieldStatistic> {
              new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
              //Note: NoStatistics option for FieldStatisticsFlag is not supported.
      var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
    Modify the report Page
        Height = 12,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
      report.SetPage(cimReportPage);
      //Change only the report's page height
      report.SetPageHeight(12);
    Requirements
