ArcGIS.Core.Data Namespace / StatisticsDescription Class / StatisticsDescription Constructor
The Field upon which statistics functions are performed.
An IEnumerable of one or more StatisticsFunctions, specifying what statistics should be computed.
Example
    Initializes a new instance of the StatisticsDescription class.
    Syntax
    Parameters
    field
    statisticsFunctions
    Exceptions
    ExceptionDescription
    field is null.
    -or-
    statisticsFunctions is null.
    statisticsFunctions does not contain at least one valid input.
    One or more StatisticsFunctions in statisticsFunctions are invalid.
    Example
    Calculating Statistics on a Table
      // Must be called within QueuedTask.Run
      // Calculate the Sum and Average of the Population_1990 and Population_2000 fields, grouped and ordered by Region
      void CalculateStatistics(FeatureClass countryFeatureClass)
        using (FeatureClassDefinition featureClassDefinition = countryFeatureClass.GetDefinition())
          // Get fields
          Field regionField = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("Region"));
          Field pop1990Field = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("Population_1990"));
          Field pop2000Field = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("Population_2000"));
          // Create StatisticsDescriptions
          StatisticsDescription pop1990StatisticsDescription = new StatisticsDescription(pop1990Field,
            new List<StatisticsFunction>()
              StatisticsFunction.Sum,
              StatisticsFunction.Average
          StatisticsDescription pop2000StatisticsDescription = new StatisticsDescription(pop2000Field,
          // Create TableStatisticsDescription
          TableStatisticsDescription tableStatisticsDescription = new TableStatisticsDescription(
            new List<StatisticsDescription>()
              pop1990StatisticsDescription, pop2000StatisticsDescription
          tableStatisticsDescription.GroupBy = new List<Field>() { regionField };
          tableStatisticsDescription.OrderBy = new List<SortDescription>() { new SortDescription(regionField) };
          // Calculate Statistics
          IReadOnlyList<TableStatisticsResult> tableStatisticsResults =
            countryFeatureClass.CalculateStatistics(tableStatisticsDescription);
          foreach (TableStatisticsResult tableStatisticsResult in tableStatisticsResults)
            // Get the Region name
            // If multiple fields had been passed into TableStatisticsDescription.GroupBy, there would be multiple values in TableStatisticsResult.GroupBy
            string regionName = tableStatisticsResult.GroupBy.First().Value.ToString();
            // Get the statistics results for the Population_1990 field
            StatisticsResult pop1990Statistics = tableStatisticsResult.StatisticsResults[0];
            double population1990Sum = pop1990Statistics.Sum;
            double population1990Average = pop1990Statistics.Average;
            // Get the statistics results for the Population_2000 field
            StatisticsResult pop2000Statistics = tableStatisticsResult.StatisticsResults[1];
            double population2000Sum = pop2000Statistics.Sum;
            double population2000Average = pop2000Statistics.Average;
            // Do something with the results here...
    Requirements
