ArcGIS.Core.Data Namespace / Table Class / Sort Method
The TableSortDescription which describes the details of how the table sort operation should be carried out.
Example
    Sort Method
    Sorts data from this table or feature class. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    tableSortDescription
    Return Value
    A RowCursor that holds the sorted Row or Feature.
    Exceptions
    ExceptionDescription
    tableSortDescription is null.
    A geodatabase-related exception has occurred.
    Example
    Sorting a Table
      //Must be called within QueuedTask.Run()
      RowCursor SortWorldCities(FeatureClass worldCitiesTable)
        using (FeatureClassDefinition featureClassDefinition = worldCitiesTable.GetDefinition())
          Field countryField = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("COUNTRY_NAME"));
          Field cityNameField = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("CITY_NAME"));
          // Create SortDescription for Country field
          SortDescription countrySortDescription = new SortDescription(countryField);
          countrySortDescription.CaseSensitivity = CaseSensitivity.Insensitive;
          countrySortDescription.SortOrder = SortOrder.Ascending;
          // Create SortDescription for City field
          SortDescription citySortDescription = new SortDescription(cityNameField);
          citySortDescription.CaseSensitivity = CaseSensitivity.Insensitive;
          citySortDescription.SortOrder = SortOrder.Ascending;
          // Create our TableSortDescription
          TableSortDescription tableSortDescription = new TableSortDescription(
            new List<SortDescription>() { countrySortDescription, citySortDescription });
          return worldCitiesTable.Sort(tableSortDescription);
    Requirements
