KnowledgeGraph Constructor
Opens a knowledge graph datastore with a
KnowledgeGraphConnectionProperties. This method must be called on the MCT. Use QueuedTask.Run.
Opening a Connection to a KnowledgeGraph
await QueuedTask.Run(() =>
//Create a connection properties
var kg_props =
new KnowledgeGraphConnectionProperties(new Uri(url));
try
//Open a connection
using (var kg = new KnowledgeGraph(kg_props))
//TODO...use the KnowledgeGraph
catch (GeodatabaseNotFoundOrOpenedException ex)
System.Diagnostics.Debug.WriteLine(ex.ToString());
Opening a Connection to a File KnowledgeGraph
//Starting at 3.7, users can connect to a _file_ knowledge graph
//The extension for a file kg is ".knowledgegraph"
// Any path you want
string kgPath = @"C:\Data\KG\Filebased_KG";
string kgFileName = @"Test_File_KG.knowledgegraph";
var kg_full_path = System.IO.Path.Combine(kgPath, kgFileName);
var kg_props = new KnowledgeGraphConnectionProperties(new Uri(kg_full_path));
try
//Open a connection
//TODO...use the File KnowledgeGraph
var i = 0;
//Get the featureclass definitions from the KG datastore
var fc_defs = kg.GetDefinitions<FeatureClassDefinition>();
//For each feature class definition, get the corresponding
//feature class. Note: The name of the feature class will match
//the name of its corresponding KnowledgeGraph named object type
//in the KnowledgeGraph graph data model
foreach (var fc_def in fc_defs)
var fc_name = fc_def.GetName();
System.Diagnostics.Debug.WriteLine($"FeatureClass[{i++}] {fc_name}");
Retrieving GDB FeatureClasses and Definitions
var kg_props =
//Connect to the KnowledgeGraph datastore
//KnowledgeGraph datastores contain tables and feature classes
using (var fc = kg.OpenDataset<FeatureClass>(fc_name))
//TODO - use the feature class
Retrieving GDB Tables and Definitions
var kg_props =
//Get the table definitions from the KG datastore
var tbl_defs = kg.GetDefinitions<TableDefinition>();
//For each table definition, get the corresponding
//table. Note: The name of the table will match the name
//of its corresponding KnowledgeGraph named object type in
//the KnowledgeGraph graph data model
foreach (var tbl_def in tbl_defs)
var tbl_name = tbl_def.GetName();
using (var fc = kg.OpenDataset<Table>(tbl_name))
//TODO - use the table
ArcGIS Pro version: 3.2 or higher.
