Public Overrides NotOverridable Function GetConnector() As Connector
public override Connector GetConnector()
Return Value
The ArcGIS.Core.Data.Connector associated with the currently opened knowledge graph data store.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
//Create a connection properties
var kg_props =
new KnowledgeGraphConnectionProperties(new Uri(url));
//Connect to the KnowledgeGraph datastore
//KnowledgeGraph datastores contain tables and feature classes
using (var kg = new KnowledgeGraph(kg_props))
var connector = kg.GetConnector() as KnowledgeGraphConnectionProperties;
var uri = connector.PathOrURL;
var serviceUri = uri.AbsoluteUri;
