ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraph Class / GetDefinition<T> Method
The type of dataset definition.
The name of the table to open.
    GetDefinition<T> Method (KnowledgeGraph)
    Gets the ArcGIS.Core.Data.TableDefinition or ArcGIS.Core.Data.FeatureClassDefinition associated with name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDefinition(Of T As Definition)( _
       ByVal name As String _
    ) As T
    public T GetDefinition<T>(
       string name
    where T: Definition
    Parameters
    name
    Type Parameters
    T
    Return Value
    Exceptions
    ExceptionDescription
    No valid knowledge graph data store has been opened prior to calling this operation.
    The knowledge graph data store does not support the Definition type requested.
    name cannot be null or an empty string.
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
