ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraph Class / GetDefinitions<T> Method
The type of dataset definition.
Example
    GetDefinitions<T> Method (KnowledgeGraph)
    Gets an IReadOnlyList of specific ArcGIS.Core.Data.Definition instances associated with each dataset of type T in the knowledge graph. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDefinitions(Of T As Definition)() As IReadOnlyList(Of T)
    public IReadOnlyList<T> GetDefinitions<T>()
    where T: Definition
    Type Parameters
    T
    Return Value
    A IReadOnlyList of specific ArcGIS.Core.Data.Definition instances corresponding to type T.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    Asking for ArcGIS.Core.Data.TableDefinition will only return definitions for non-spatial tables (not feature classes), but asking for ArcGIS.Core.Data.FeatureClassDefinition will return regular feature classes.
    Example
    Retrieving GDB FeatureClasses and Definitions
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        //Connect to the KnowledgeGraph datastore
        //KnowledgeGraph datastores contain tables and feature classes
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the featureclass definitions from the KG datastore
          var fc_defs = kg.GetDefinitions<FeatureClassDefinition>();
          //For each feature class definition, get the corresponding
          //feature class. Note: The name of the feature class will match
          //the name of its corresponding KnowledgeGraph named object type
          //in the KnowledgeGraph graph data model
          foreach (var fc_def in fc_defs)
            var fc_name = fc_def.GetName();
            using (var fc = kg.OpenDataset<FeatureClass>(fc_name))
              //TODO - use the feature class
    Retrieving GDB Tables and Definitions
        var kg_props =
          //Get the table definitions from the KG datastore
          var tbl_defs = kg.GetDefinitions<TableDefinition>();
          //For each table definition, get the corresponding
          //table. Note: The name of the table will match the name
          //of its corresponding KnowledgeGraph named object type in
          //the KnowledgeGraph graph data model
          foreach (var tbl_def in tbl_defs)
            var tbl_name = tbl_def.GetName();
            using (var fc = kg.OpenDataset<Table>(tbl_name))
              //TODO - use the table
    Requirements
    ArcGIS Pro version: 3.2 or higher.
